 oldmgsMember
Trying to remove the rear brake drum. Split the chain case and removed the sprocket and circlip. Clamped the spline in the big vice and tried to remove the large domed nut on the drum side – but can’t budge it. Tried heat as well. Before I try very long breaker bar and/or a big hammer thought I would check if by any chance it is a right hand thread? Any other suggestions gratefully received. Though perhaps I could knock the spline through, but does not seem to be the case.
Cheers
Douglas
 BlairMember
Hi Douglas
I am thinking its a 501 you have, makes sense with big domed nut… and yes I think it is the opposite thread than usual.
I am not 100% sure, but pretty much think it is.
Good luck. mate.
Regards
Blair
